It is a Dealer Recall of the Clock Spring in the instrument cluster. BUT that will not be your only problem-I have been through hours and hours of problems that seem to be the Body Module but most turn out to be an "imbalance" in system whether its vacuum, hydraulic or electric. A simple ground or loose wire or vacuum leak can cause FALSE READINGS of major components. Feel free to call anytime if your headlights blow, dr or windows switches die, gauges go out,head/ brake light stays on , blinkers fail, etc. (970)310-4494
Scoyboy
Sep 3, 2010 at 9:10 AM
