1992 Dodge Caravan turn signals,heater and airbag light
235,000 MILES • 6 CYL • FWD • AUTOMATIC
JOALKL
here it is we had an overcharging problem had alt tested it was bad replaced it,now the airbag light is on and turn signals and heater blower dont work no power to either fuse traced wires from fuse block to ign. switch have power going in but not out replaced switch still have same problem tried 2 new switches from differant manufactures if i jumper terminals on plug to ign switch everything works fine
Oct 30, 2010 at 10:25 AM
  • 110,244 POSTS
If you have power in but not out, and it works if you jump it, it has to be in the switch. Have you checked continunity in the switch?
Nov 1, 2010 at 1:21 AM
JOALKL
yes i did and i found that i was tracing wrong source have no power in i think i have solved the problem found that i was looking at wrong power source on plug only have one power in should have two
Nov 1, 2010 at 7:51 AM
  • 110,244 POSTS
Let me know the final outcome or if you have other questions.
Nov 1, 2010 at 12:46 PM
