1999 Dodge Grand Caravan EGR and Airbag Fix
KIMHOYT1
  • 5 POSTS
I have a 1999 dodge grand caravan se 109000 miles. My service engine light is on steady, code 401 egr fault. The airbag light comes on intermittently then will go out, when lit the horn will not work. I had the fault code read while the airbag light was on and it showed no fault except EGR fault. The van runs fine no matter what light is on/
Jun 6, 2006 at 4:28 AM
LOSONE
  • 1,616 POSTS
The horn and air bag light is caused by a bad clock spring assembly between the steering wheel and the column.
It will not pass any emissions test with a bad EGR valve so have it replaced or repaired. Good luck
Jun 6, 2006 at 6:26 AM
TMFRENDA
  • 7 POSTS
Other than replacing it can it be clean out soot in there some where
Jun 8, 2006 at 1:02 AM
KIMHOYT1
  • 5 POSTS
Anyone know how difficult it is to change the clock spring or how expensive it is to replace one? It looks rather difficult from the repair manual.....
Jun 14, 2006 at 3:32 PM
VANDRAGON
  • 298 POSTS
there is a recall on the clockspring for your van. call a dealership and go there, it should be free, then you will have a one year warrenty if it happens again....hope this helped....vandragon
Jun 16, 2006 at 10:36 AM
Suggested Repair
Have the EGR valve repaired or replaced so the code 401 fault can pass emissions. For the intermittent airbag light and inoperative horn, have a dealer check the clock spring recall; replacement may be free and include a one-year warranty.
Conversation Summary
A 1999 Dodge Grand Caravan has a steady service engine light with code 401 EGR fault, plus an intermittent airbag light that disables the horn. The van otherwise runs fine. Experts attributed the airbag and horn issue to a faulty clock spring and said the EGR valve should be repaired or replaced. A later reply said a clock spring recall may cover the repair at a dealership.
