1999 Dodge Grand Caravan Electrical Failure
PEDWARDS63
I have a 1999 Dodge Grand Caravan 3.8L with 115K miles on it. Drives fine most of the time but recently while driving the oil light came on, brakes malfunctioned, power steering failed, stereo was out. When stopped the van wouldn't turnover. Waited 10 minutes and it started and drove back home without issue. I was told a few months ago by dealer that main wiring harness was corroding due to battery acid leak. Does this sound like a wiring harness issue?
Jan 15, 2007 at 8:19 AM
SERVICE WRITER
  • 9,123 POSTS
It certainly has credence. I would definitly get a look at the wiring in that area.
I did a little reasearch for you and there is a splice that is located near the positive battery terminal in the main harness. I would pull off the electrical tape around it and take a look inside. My guess is you'll find some green.
Jan 15, 2007 at 8:58 AM
Suggested Repair
Inspect the main wiring harness splice near the positive battery terminal. Remove the electrical tape and look for green corrosion from battery acid, then repair or replace any damaged wiring.
Conversation Summary
The owner of a 1999 Dodge Grand Caravan reported that the oil light, brakes, power steering, and stereo failed while driving, followed by a no-start that recovered after about 10 minutes. A dealer had previously said the main wiring harness was corroding from a battery acid leak. The expert advised inspecting the splice near the positive battery terminal under the electrical tape for green corrosion.
