2000 Dodge Caravan AC Compressor
RVANHUSS
Air Conditioning problem
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have had 5 compressors put on and they would only last a few days. The last one lasted almost a year before locking up. I had one installed today and it lasted only 20 mins. The mechanic thinks there is a problem with the cooling fans coming on, they will not come on until it reaches 250. He believes that by the fans not coming on soon enough it is causing the compressor to go out. The relay for the cooling fans was just replaced a few months ago. Do you have any ideas as to what may be causing my problem?
Apr 28, 2008 at 1:24 PM
  • 31,937 POSTS
Hi there,
I would be checking the internals of the compressor, to see what has failed, is there enough oil in the compressor? has one of the earlier compressors failed and contaminated the system with debris that is circulating and causing a problem, i feel that these will be one of your problems.
Mark (mhpautos)
Apr 28, 2008 at 2:20 PM
