2000 Dodge Caravan Hood Paint Bubbling
RICENHOUR
My 2000 Dodge Caravan, 100K Miles, 3.3L engine temp reaches nominal temp very quickly. Ususally withing 2-3 miles of driving. But does not read HOT. The temperature gauge reads normal but the engine compartment is extremely hot. So much so that the paint on the hood is bubbled in places and too hot to touch. The car does not burn oil and is not leaking any fluids. It runs completely normal otherwise. What could this be?
Aug 3, 2007 at 2:06 PM
  • 75,988 POSTS
[quote:c276e6d8e2="ricenhour"]My 2000 Dodge Caravan, 100K Miles, 3.3L engine temp reaches nominal temp very quickly. Ususally withing 2-3 miles of driving. But does not read HOT. The temperature gauge reads normal but the engine compartment is extremely hot. So much so that the paint on the hood is bubbled in places and too hot to touch. The car does not burn oil and is not leaking any fluids. It runs completely normal otherwise. What could this be?[/quote:c276e6d8e2]
For a start try changing the thermostat and see what happens.
Aug 5, 2007 at 1:57 AM
Suggested Repair
Replace the thermostat first, then recheck whether the engine compartment still overheats while the temperature gauge reads normal.
Conversation Summary
The owner of a 2000 Dodge Caravan with a 3.3L engine and about 100,000 miles says the gauge reaches normal temperature within a few miles and never reads hot, but the engine compartment becomes extremely hot, bubbling hood paint and making the hood too hot to touch. The vehicle does not burn oil, leak fluids, or otherwise run abnormally. The expert recommends starting by replacing the thermostat and checking the result.
