What is the easiest way to remove and replace the hood release cable?
93 Dodge Caravan
93 Dodge Caravan
May 25, 2007 at 7:04 AM
Open the hood, remove the four or five hinge bolts, and release the cable clip. Inside the vehicle, release the clip at the kick panel and the plastic clips holding the cable, then pull the cable through. Install the new cable in reverse order.
The owner of a 1993 Dodge Caravan asked for the easiest way to remove and replace the hood release cable. The expert advised opening the hood, unbolting the hinge, releasing the cable clips at the latch and kick panel, pulling the cable through the vehicle, and installing the replacement the same way.
