1999 Dodge Caravan
TOM10
  • 1999 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 100,000 MILES
Cooling fan did not turn off after key was taken out.
Tryed dissconecting and reconecting battery leads,
still ran. I removed the fan relay and when I replaced it fan turned off, but has not come on again
even with engine temp being up.
Monday, October 27th, 2008 AT 4:31 PM
BMRFIXIT
  • 19,053 POSTS
Turn AC on
fan should come on if not make sure you have the correct relay
and was installed correctly
I would suspected the module relay on the frame behind grille
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Monday, October 27th, 2008 AT 9:27 PM
