2000 Dodge Caravan Cooling system
152,000 MILES • 4 CYL • 2WD • AUTOMATIC
SANDY9999
The engine cooling fan continues to run non-stop after turning off the vehicle (in 30 degree weather), is this likely a switch or computer problem?
Feb 2, 2008 at 1:09 AM
BMRFIXIT
  • 19,053 POSTS
[quote:387402c3c7="Sandy9999"]Other Category problem
2000 Dodge Caravan 4 cyl Two Wheel Drive Automatic 152000 miles
The engine cooling fan continues to run non-stop after turning off the vehicle (in 30 degree weather), is this likely a switch or computer problem?[/quote:387402c3c7]
check coolant level
do you have a check engine light on ?
i would check for code s
because if it a sensor or relay it will show
Feb 2, 2008 at 12:54 PM
