1998 Dodge Caravan wont start at times.
KEVISFORDADVISOR05
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 151,000 MILES
At times vehicle starts then stalls a few times then wont even crank over either let set or replace computer then it will start seems to happen every week I have replaced computer several times every time I replace it it does start but after a week same thing, no warning nor does it die when driving only after shutting off for a while?Confused
Monday, April 19th, 2010 AT 8:01 PM
LEGITIMATE007
  • 5,121 POSTS
Check fuel pressure and spark, when this no start situation occurs, that way we know what direction to go in, I dont believe your problem is the computer.
Tuesday, April 20th, 2010 AT 8:06 AM
TOBY1437
  • 5 POSTS
I had this problem or one almost exactly like it for almost a year.
The reason it does not start after the 3rd try is because the manufacturer alarm sytem engages. ( Grab a lunch you could be stuck anywhere from an hour to a day!)
Turn key to the "on" position; if green led mileage and PRNDL do not light up, turn "off" and smack the plastic on the instrument panel and turn "on" again. They may light based on the severity of the problem.
REGARDLESS: Before you spend $700 plus on a BCM or some other computer the dealer recommends, try this.
96 to 2000 Caravans, Town & Countries, others notoriously have bad solders on the back of the instrument panel and 95% of the time this is what is causing the intermittent problem.
FIX: Remove the instrument panel it's a little tricky but take your time. On the back of the panel there is a red connector with several wires soldered to it. These are cracked! (I needed a magnifying for mine) Have them cleaned up and resoldered. You can have the rest of the solders checked, but these should be you problem. GOOD LUCK
Tuesday, May 4th, 2010 AT 10:01 AM
LEGITIMATE007
  • 5,121 POSTS
Thanks for the input toby
Tuesday, May 4th, 2010 AT 11:08 AM
