3.0L Grand Caravan SE with LPG conversion
When key is turned then ignition comes on but does not turn over. It is almost like it is in Drive or Reverse trying to start.
This occured occaionally before but went away after opening and closing doors via 3rd party alarm system/remote central locking.
Therefore I had the alarm totally removed but no change in behaviour - i.e will not start. Yellow starter lead shows 12v when key turned.
The garage cannot find problem. Engine check light has been on with code P0403 since valve seats replaced for loss compression in 1 cylinder.
Other (related?) issues is that a/c and rear heater lights flash for 20 minutes then turn off. a/c and rear heater works OK even when flashing.
Garage usless here as I am in UK and they sell Chrysler not Dodge and not 3.0L engine. :shock:
Aug 4, 2007 at 7:51 AM
