1998 Dodge Caravan Wont Start
GERSAIN92
  • 1998 DODGE CARAVAN
  • 6 CYL
  • 375,000 MILES
Every couple of weeks it'll do this thing where it'll start and stall after a few seconds, no matter how much gas you give or whatever. So you star it up again and it stalls out again after a few seconds. It'll do this 3 or 4 times and then when you turn the key it won't do anything. No cranking, no click, no nothing. Acts like you're trying to start it in drive or without a battery or something. But all lights, radio, everything works except it does nothing when you turn the key. You let the car sit and the next morning or later on in the evening it starts as if there's no problem. Works great for a while and then the cycle repeats.
Dealer kept it for 2 days and can't find anything wrong. They even sent it out with the delivery guy and drove it for 20 miles and still no problem. Says he can't fix what he can't find. Thankfully they didn't charge me a cent.
Has anyone had an experience like this (i.E, is this a known issue for the 98 Caravan)? Preferably with a known solution? I did some searches and some folks say PCM but I have yet to see someone say PCM and then come back later and say yes it really was the PCM.
Tuesday, November 17th, 2009 AT 7:45 PM
BMRFIXIT
  • 19,053 POSTS
Suspect ignition switch 1st and or BCM
Tuesday, November 17th, 2009 AT 7:48 PM
ROLANDS J ABERMANIS
My 98 Caravan does the same thing.
Starts for a few seconds then stalls.
After 4 times there is nothing.
Did the ignition switch solve the problem?
Tuesday, December 1st, 2009 AT 1:00 PM
BMRFIXIT
  • 19,053 POSTS
Do you have a security light on
check battery terminals
make sure its clean and tight
check for codes as it should set a code
if its cranking and no start check for fuel pressure and suspect fuel pump
check for spark
open hood and mark relays and switch the around
ASD relay
Tuesday, December 1st, 2009 AT 8:57 PM
