1998 Dodge Caravan won't start
DEE JOHNSON
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 12,400 MILES
It won't start
Saturday, April 11th, 2009 AT 5:46 AM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, April 11th, 2009 AT 6:36 AM
