1998 Dodge Caravan Cranks But Won't Start
OR
does not crank and nothing happens when the key is turned?
If it cranks it is not a starter problem as the starter is cranking the motor or turning over the motor.
There is spark, fuel or compression missing. Try spraying some starting fluid in the throttlebody and check to see if it will start for a moment then.
Suggested Repair
Because the engine cranks, the starter is not the problem. Check for spark, fuel, and compression. Spray starting fluid into the throttle body to see if it fires briefly. The battery is supplying enough power to crank, so the ignition coil is the more likely of the two codes.
Conversation Summary
A 1998 Dodge Caravan with a 6-cylinder engine started normally, then later cranked but would not start while the electronics still worked. The owner suspected the starter. The expert clarified that cranking means the starter is working and that spark, fuel, or compression is missing, and suggested a starting-fluid test at the throttle body. After codes pointed to the battery and ignition coil, the expert said the battery was adequate and the coil was the more feasible cause.
