1998 Dodge Caravan My Dodge cranks well. But won't start
DOUGLASMONT
  • 1998 DODGE CARAVAN
  • 6 CYL
  • 100,000 MILES
It seems like it's maybe not getting spark. No signs of sputtering just cranks.
Tuesday, June 22nd, 2010 AT 12:37 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tuesday, June 22nd, 2010 AT 3:11 PM
