1998 Dodge Caravan flashing head lights
DABB78
Electrical problem
1998 Dodge Caravan 6 cyl Two Wheel Drive Automatic
I turned my van off to wash it one day, after washing it I turned it on to moved it and noticed that my head lights were flashing. They stop flashing when the switch is in the on position, but start flashing as soon as they are switched off. Could this be a problem with a relay or fuse maybe, if so how can I fix it?
Jan 24, 2009 at 2:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is your vehicle equipped with daytime running lamps? If so inspect light sensor on dash to ensure nothing is covering it. Also check high beam and low beam relays, located in the power distribution center, under hood. For information on checking a relay, follow the link below.
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Thanks for using 2CarPros.com!
Jan 24, 2009 at 2:47 PM
TONE94SHADOW
  • 8 POSTS
Does your car have an anti-theft device either aftermarket or factory?if so it may have to be reprogramed
Jan 26, 2009 at 9:09 AM
