1999 Dodge Caravan High Beams
153,000 MILES • 6 CYL • FWD • AUTOMATIC
MOMCOW
Low beams work, but when I pull for high beams lights go out completely. Checked fuses, replaced multi-function switch, checked relays. Checked bulbs, still no high beams, any suggestions.
Feb 11, 2009 at 8:42 PM
ZACKMAN
  • 4,202 POSTS
Do you have daytime running light? If yes, check operation of stop lights.
How did you check the high beam relay?
Feb 12, 2009 at 4:33 PM
MOMCOW
I checked the relay by swapping with a known good one. Still, no luck.
Feb 13, 2009 at 9:50 AM
ZACKMAN
  • 4,202 POSTS
[quote:492c35b319="Zackman"]Do you have daytime running light? If yes, check operation of stop lights.
[/quote:492c35b319]
Do you? Wiring diagrams are more complicated with them.
Feb 13, 2009 at 2:31 PM
MOMCOW
yes, have daytime running lights, also checked stop lights, everything good there.
Feb 14, 2009 at 9:50 PM
ZACKMAN
  • 4,202 POSTS
As you have replaced the high beam relay, and checked fuses #4 and #5 (inside the engine compartment), checked the operation of the stop light, the next in line is the multifunction switch.
Feb 16, 2009 at 1:49 PM
