1998 Dodge Caravan HEADLIGHT WON'T TURN OFF
149,899 MILES • 6 CYL • 2WD • AUTOMATIC
DANILO_ESTUDILLO
MY HEADLIGHT WON'T TURN OFF EVEN I TURN OFF THE SWITCH AND REMOVE THE KEY STILL ON IT DRAIN MY BATTERY SO I JUST REMOVE NEGATIVE CABLE FROM MY BATTERY SO IT WONT DRAIN THE BATTERY
Sep 13, 2009 at 2:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
are they stuck on low beam or high beam? does switching it from one to the other change the lights? check your low beam and high beam relays. they are located in the power distribution center. if they are both OK, suspect faulty headlamp switch.
Sep 13, 2009 at 2:11 PM
