1998 Dodge Caravan
JOHNYCEE46
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 11,800 MILES
How much work is involved in valve cover gasket replacement
Monday, March 9th, 2009 AT 2:51 PM
  • 109,885 POSTS
WHick V6 do you have?
Monday, March 9th, 2009 AT 4:08 PM
JOHNYCEE46
I have the 3.0 V6
Monday, March 9th, 2009 AT 4:44 PM
  • 109,885 POSTS
Hi:
The book calls for 2.5 hours in labor and 25.00 for OEM parts.
The reason for the hours labor is because you need to remove the plennum to replace the rear cover. It is some work, but if you take your time and have a little mechanical ability, you should be able to do it.
If you need a manual, go to:
https://www.2carpros.com/kpages/auto_repair_manuals.htm
This is cheaper than purchasing a manual.
joe
Monday, March 9th, 2009 AT 7:50 PM
