2001 Dodge Caravan Valve Cover Gasket Leaking
85,200 MILES • 6 CYL • FWD • AUTOMATIC
CARA HERNANDEZ
What is reasonable cost to repair Valve Cover Gasket leak. Recently had tune up on car and I read spark plugs and wires need removed to replace valve cover gasket. Is that the case - seems a bit odd they'd do the tune up w/all these parts being replaced and then when done and bill paid, they advise I need valve cover gasket replaced? having to pull out what they just put on?
Nov 21, 2008 at 1:42 AM
  • 110,248 POSTS
Hi:
You will need to remove the plug wires, but not the plugs. As far as cost, it matters what size V6 you have. A rough est. would be around 250.00.
I hope this helps.
Nov 23, 2008 at 11:38 AM
