1997 Dodge Caravan Coolant leak
19,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEYG45
I started my van and what I thought was the universal belt was squieling. I checked the radiator level and added water to top it off. After adding 4 gallons and it still wasn't full, I noticed a large puddle under the engine. Upon looking, could see water running out from somewhere on the passenger side of the engine. I couldn't see from where exactly. It leaked from the same side the belt is mounted on. Where can this be coming from? I have a Haynes manual and haven't checked it yet. It doesn't seem to be holding any coolant in the radiator. I haven't driven it since this happened. Any ideas or advice would be greatly appreciated. My wife and I are on disability and can't afford much. Thanks for any help given.
Nov 23, 2008 at 10:24 PM
BMRFIXIT
  • 19,053 POSTS
Check water pump and hoses
if you have rear heater unit
heater hoses/lines known to rust and leak coolant out
check it out
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 23, 2008 at 10:52 PM
