1997 Dodge Caravan changed fuel filter
TAZ0767
Engine Performance problem
1997 Dodge Caravan 6 cyl Automatic
My vehicle will start up and idol. As soon as i push gas pedel down more then half way it stales. I change fuel filter hoping that was my problem. It ran good for about 10 minnutes now it back to doing the same thing.
Feb 13, 2009 at 5:06 AM
JDL
  • 16,098 POSTS
Are there any codes? Can you tell if the system is going rich or lean? Is the fuel pressure ok?
Feb 13, 2009 at 5:26 AM
TAZ0767
How would you be able to know what the code is? could it mean water in the tank?
Feb 13, 2009 at 5:36 AM
JDL
  • 16,098 POSTS
To check codes on your vehicle, you may need an obd11 code reader. Some national brand autostores will check some codes for free.
It could be almost anything, right now, it seems like the system is going lean when you open the throttle. Can you check fuel pressure?
Feb 13, 2009 at 7:55 AM
TAZ0767
thank you so much
Feb 13, 2009 at 9:29 AM
DSTER911
I have the same problem with my 1997 Carvan. Could you share the feedback you received.
dster911@yahoo.com
Mar 23, 2009 at 12:34 PM
