1997 Dodge Caravan Gas Tank
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
SENTZJ
Hi, for some reason my gas light is always on & its always on empty even when I know I just filled up the gas tank. What should I do? Is this something that can get expensive?
Mar 31, 2010 at 6:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
would suspect faulty fuel sending unit, its in the gas tank.
Mar 31, 2010 at 6:11 AM
SENTZJ
thank you for answering my question :) do you know if that is something expensive to do?
Mar 31, 2010 at 7:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
only takes about an hour for the job which will be around $70 in labor costs. as for the part itself, it will be around $160 , so looking at approx. $230 total.
Mar 31, 2010 at 7:07 AM
