Gas smell in side the vehicle when the heater motor is running. Any suggestion?
Oct 20, 2009 at 2:21 AM
✓Experienced Mechanic
If you smell it in the car with the fan on, chances are the leak is under the hood. Check all fuel injectors, fuel lines, pressure regulator... Any fuel leak can be dangerous.
