1997 Dodge Caravan brakes
RMISSBEC
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 120,000 MILES
I have replaced the front calipers, rotors, brake pads. Left and right brakes hoses. Front right caliper sticks and does'nt release. Replaced caliper again and it still don't release. Do you have any other suggestions to locate the problem. Your help is appreciated!
Monday, March 24th, 2008 AT 8:22 PM
RAMVAN
Check to see if you may have crimped a line to the caliper. If not the problem may be in your brake booster. Usually they are controlled by vaccuum. If there is no vacuum pressure at the booster it may cause this problem.
Sunday, February 21st, 2021 AT 1:16 PM
