brake trouble
800,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
WHATUPDOC
my front drive side caliper get hot.i put new caliper and new hose both side,and new master cycliner .new brake fluid..bleed all wheels.new rotor and pads.it been going on for 3 months..ever since i slam on my brake the front drive caliper wont release..that why i put new caliper on..i have no abs lights on dash.the power booster is working good.before i put all new it was doing it.ty i hope u can help me out,am going nuts.
Dec 19, 2015 at 8:25 AM
HMAC300
  • 48,601 POSTS
have a local pro scan for codes it may be an abs problem even though light isn't on. front brakes will normally be hot to touch anyhow.
Dec 20, 2015 at 12:41 AM
WHATUPDOC
i have abs scan tool and no code show.
Dec 20, 2015 at 12:50 AM
WHATUPDOC
get hot smoke come from caliper.
Dec 20, 2015 at 12:53 AM
HMAC300
  • 48,601 POSTS
your scanner can't check each system of an abs like a pro model can it will only show codes and erase them nothing else. if you have replaced thehoses and your caliper doesn't stick and slides easily then it has to be an abs problem you might recheck the things I've just mentioned prior to having a pro look at it. make sure your caliper pins aren't hanging up . if your brake fluid wasn't changed until now it may have gotten a piece of junk in abs unit causing it. you might try a power bleeder to rebleed the system once again if you didn't already
Dec 20, 2015 at 1:18 AM
