1996 Dodge Caravan Van will try to start but it wont start
MOTIWAL
  • 1996 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 158 MILES
Start some time run no problems if I stop the engine will not start again tries to start after few second dies will start after 6 or 7 hr I changed my plugs before this problem the thing I checked relays fuses all good the only thing I noticed when its not start at that time I don't see any power to the speedometer fuel heat and rpm and also not showing the park. Nut.R. Digital signs on the upper dash I can see oil can sign abs parking brake after turning the switch to on position engine tries to start and after starting it dies. But when ever I see all gags move I know the van will start. Any buddy know what the hell is going in my life with this van.I cant go no where because I know it may not start iand I have to leave it the for 6 to 7 hr please help me
Saturday, June 12th, 2010 AT 8:29 AM
  • 109,874 POSTS
I need to know a couple things. First, when it doesn't start, have you checked to see if there is spark and fuel to the engine? Also, has the check engine light come on?
Monday, June 14th, 2010 AT 12:02 PM
MOTIWAL
Hyay thanks for your reply
!)No engine ck light
2)yes fuel and spark
3)the console is not getting power
4)after few second it die aging
5) leve it over night it will start normal
6)runs all day with out turning off the engine once engine off wait over night or 6 to 7 hrs
Monday, June 14th, 2010 AT 5:28 PM
  • 109,874 POSTS
If you are getting spark and fuel, it should run. Is the spark a blue snapping hot spark or is it orange or white in color? Have you ever tried starting it with starting fluid when it does this?
Wednesday, June 16th, 2010 AT 11:26 PM
