1996 Dodge Caravan enginie just turns
RUSTLIN129
Engine Mechanical problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic 126.00 miles
went out in the morning car would not start, enginie ljust turns and turn what could cause that
Feb 19, 2009 at 2:23 AM
JDL
  • 16,098 POSTS
Hello, the problem could be almost anything. Can you check for codes? Some makes and models you can get codes by cycling the ignition switch, three times, on--off, on--off, on, within 5 seconds.
You just turn the key on till the dash lites come on further. The mil starts flashing, you count the flashes to get the codes.
You can also do some basic tests, have a helper crank it, while you check for spark at the plugs and injector pulse.
Feb 19, 2009 at 2:36 AM
