1996 Dodge Caravan engine stalls without warning
247,582 MILES • 6 CYL • FWD • AUTOMATIC
ALPHIEBOT
About a week ago, my 1996 Dodge Caravan (247,000 miles) wouldn't start. There was no power to the dash or dome light, and the only a relay buzzing from under the dash. I jump-started the car, and it ran fine afterwards. Today, I had the engine cut off on the freeway. RPMs shot down to 0, but the car started again immediately after pulling over. Since then, it's done it twice more, without any particular warning.
It seems like this is an electrical problem, as opposed to fuel deprivation, but I'm not sure where to start on this- the fuses tested fine, the relays seemed OK to eyeball inspection. What might be the problem?
Sep 1, 2009 at 4:08 PM
JDL
  • 16,098 POSTS
You need to be sure the battery has a full charge, all connections are good and the charging system is working ok. Are there any codes? When you talked about the dash lites, made me wonder about the ignition switch, I can't be sure? When the problem occurs, if the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the plugs. Go from there.
Sep 21, 2020 at 5:58 AM
