1996 Dodge Caravan 3.3 engine die after about 5 min
N5WWV
  • 1996 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 200,000 MILES
Engine dies
Sunday, August 8th, 2010 AT 9:38 PM
  • 109,755 POSTS
Have you checked fuel pump pressure? Has the check engine light come on?
Monday, September 21st, 2020 AT 1:04 PM
N5WWV
Yes the check service soon lite is lit but dont know how to check pressure on the fuel pump other than listen to sound it makes when you turn key on and off it wirls and then stops. What do I need to check pressure and where?
  • 109,755 POSTS
Here is a how to for checking fuel pump pressure. You will need a gauge, but most parts stores will lend or rent them to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
I also recommend having the computer scanned to identify why the check engine light is on. Most parts stores will do it for free, and it may help identify the problem.
