1996 Dodge Caravan Engine clatter noise
1996 DODGE CARAVAN
149,000 MILES • 6 CYL • FWD • AUTOMATIC
DLVRYMAN1
Vehicle starts hard and clatters. Sounds like its coming from top end like loose rocker arms but not sure. I removed and checked the front rocker assembly. Ran with valve cover removed to check lubrication. Lubrication good. Did compression test on front 3 cylinders, all above 120 psi. Waiting for warmer weather to check the rear 3 cylinders! Service engine soon light also on. Could timing chain have jumped? Any advice ?
Dec 25, 2008 at 4:41 AM
  • 110,244 POSTS
Hi:
Is the engine still running good other than the noise? If so, timing shouldn't be an issue. Does the sound go away after the car runs? also, if the van has a 3.3L, check for a broken rocker tower. There were some problems with them cracking (rear head) which means a new head.
Let me know what you find.
Dec 26, 2008 at 3:14 AM
DLVRYMAN1
Today I removed the intake manifold plenum on my 96 Caravan with a 3.3. With 149,000 miles.I wanted to finish a compression test on the back 3 cylinders. All three plugs look like the were never changed but they must have been at least once because the were Autolites ! The plugs were obviously in for a long time because the electrode was very thin to give you an idea gap was about .080 Compression test came out higher than the front bank by about 25 pounds. Removed valve cover and as I pulled it off I bumped it and heard the wonderful sound of clatter! The noise has been found! All of the rockers were worn out severe wear through the shaft! I bought this van (a southern gem)a couple days ago at a very fair price with the noise hoping for a simple fix like a broken valve spring , bent pushrod,or badly worn rocker. I am happy to have found the noisemakers way up top on this 3.3. I am wondering though, why the failure? No broken towers here. Evidence of some sludge but nothing major. I blew through the pushrods to make sure they were clear. What do you think? I am going to put the new shaft and rockers on tomorrow even though there is some wear on the tops of the valves from the rockers riding funny,Good Lord Willing! I am replacing the push rods to help compensate for the wear on the valves. I figure that new rockers and pushrods should help to close the gap. What do you think about this economy fix? And what would the root cause likely be? Gary
Dec 26, 2008 at 1:54 PM
  • 110,244 POSTS
It sounds like a plan. As far as the problem, I can't say what could have caused the problem, overheating, abuse, maintenance...
What you decided should work. And yes, I would try it to with this economy.
Dec 27, 2008 at 11:48 AM
