That code you mentioned is the Torque Converter Clutch solenoid circuit. There could be a problem in the transmission with the electircal parts. If that circuit shorts, it could be killing the engine somehow. I wouldn't think that the engine would stall if the torque converter locks up at highway speeds so something's going on electrically. This may or MAY NOT be related to your condition. I've seen numerous vehicles have similar codes and the vehicle runs fine. But, going by the information you provided, that's the code description.
Also, there's a relay called the 'Auto-Shut down' relay. It provides power to the injectors as well as the ignition coil. Perhaps there's a bad connection internally at the relay and if that circuit is interrupted, the vehicle will die, just like you turned the key off. The injectors will stop firing and so will the coil. It CAN be intermittent and cause problems just like you've described. You can trade the relay with another relay in the relay box. Most of them should be the same relay. Trade it with the horn relay if they're the same. Drive it and see if the problem is still there. If not, I bet the horn will only work intermittently. Hopefully that's it. If not, repost and we'll give it another try.
SPONSORED LINKS
Monday, September 21st, 2020 AT 12:57 PM
