1994 Dodge Caravan Oil Level Guage
DDIEBOLD7
  • 1994 DODGE CARAVAN
  • 6 CYL
  • 95,000 MILES
The oil level guage does not correspond to the dip stick level. The oil dip stick measure full on level ground - engine cold. The oil level guage only shows half full, even if engine is running. How do I fix this problem? The Haynes Repair Manual does not even address this issue. Your experience and wisdom would be highly appreciated! Thank you in advance!
Dave
Houston, Texas
Sunday, June 21st, 2009 AT 11:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I don't think your vehicle was ever equipped with an oil LEVEL gauge, are you certain you are not looking at the oil PRESSURE gauge? Which should be around the middle of gauge.
Monday, June 22nd, 2009 AT 12:33 AM
