1994 Dodge Caravan
CERICKSON
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Every time I apply the brakes my oil pressure drops and the "check guages" light comes on, if I give some gas the pressure goes back up. If let off the gas it drops again. When I start moving again it goes back to normal. What could cause this?
Jun 12, 2010 at 6:37 AM
  • 75,988 POSTS
Do you hear any type of engine knocking noises both upper and lower part of the engine?
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings
Jun 12, 2010 at 11:06 PM
