1998 Dodge Caravan Dodge Grand Caravan 3.8L low oil pressur
12,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVES694
Oil pressure warning light comes on at idle in Drive when engine fully hot. Idling at 700-800 RPM. Light goes off when RPMs increased. Oil level full & have done regular oil & filter changes every 3500-4500 miles.
Nov 24, 2008 at 6:24 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge-if normal -replace the oil pressure switch -if it continures to go low-could be the oil pump/engine bearings etc.
Nov 24, 2008 at 6:28 AM
DAVES694
[quote:5385e37555="rasmataz"]Check the oil pressure with a mechanical gauge-if normal -replace the oil pressure switch -if it continures to go low-could be the oil pump/engine bearings etc.[/quote:5385e37555]
That's what I thought....thanks.
Nov 24, 2008 at 8:09 AM
