I need some information, oh and hi, could you check the fluid first, then I want you to buy a test light(6-12volt), they sell em here if you don't have one. Read how there are fuses inside and under the hood, if one of them popped, the TCM will not power up. If it was a sensor, it would not start out already in limp-in but as the failure occurs, would drop it in 2nd. So I need one more thing, the fault codes out of the Chrysler diagnostic connector. I have a feeling a fuse, or fuse link burned. Fuse links are wires that burn to open the circuit, so check them if this is your setup. It changed earlier in caravans to fuses but may still have fuse links. The fuses are in a power center near the battery if you have the plastic fuses instead of the link wires. Test everything with key on and power on both sides of the fuse or fuse link. If it just happened and the alternator was over charging, it may have burned somrething in the system, I hope not the TCM transmission computer.
Fluid, fuses, codes. Have a nice day and please be careful. Thanks
SPONSORED LINKS
Friday, April 16th, 2010 AT 2:58 PM
