HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Drivetrain
Transmission
Symptoms
Not Shifting
SPONSORED LINKS
1993 Dodge Caravan downshifts
TBOW7
MEMBER
1993 DODGE CARAVAN
6 CYL
AWD
AUTOMATIC
172,000 MILES
My trans will downshift while driving.I can pull over turn the key off and then restart then it shifts properly. What should I do
Tuesday, June 22nd, 2010 AT 4:25 PM
MECHANIC
Has the check engine light come on? Also, have you had the trans control module (TCM) checked?
SPONSORED LINKS
Tuesday, June 22nd, 2010 AT 6:44 PM
TBOW7
MEMBER
1 POST
Thanks guys: engine light doesn"t come on.I will get that other thing checked. Thanks again
Wednesday, June 23rd, 2010 AT 9:21 PM
MECHANIC
I'm glad to help. Honestly, that is what it sounds like to me. Let me know what you find.
Wednesday, June 23rd, 2010 AT 11:29 PM
Please
login
or
register
to post a reply.
Related Transmission Not Shifting Content
1993 Dodge Caravan Tranny Not Shifting
Hi There. We Had Changed The Alternator In Our 1993 Caravan, And After That It Will Not Shift Up. I Was Looking On Your Pages Earlier About...
Asked by
christy2139
1993
DODGE CARAVAN
Transmission At Times Does Not Shift From Lower Ranges
Transmission At Times Does Not Shift From Lower Ranges To Higher Range Unless You Stop The Vechile Turn Off The Engine And After Restarting...
Asked by
linda campbell
1 ANSWER
1993
DODGE CARAVAN
Transmission Not Shifting Properly And Code P0888
I Have Problem With Automatic Transmission It Is Not Shifting. And I Have The Fault Code P0888.
Asked by
faisal.nagem
5 IMAGES
2004
DODGE CARAVAN
1998 Dodge Caravan Not Shifting When Warm?
I Need A Little Help Before Calling The Repair Man. While Driving The Other Day My Van Jerked A Little, Like It Quickly Down Shifted. It...
Asked by
zaw1122
1998
DODGE CARAVAN
Will Not Shift
My Transmission Shifts From First To Second When The Van Is First Started And Stays In Second From There On And The Speedo Also Does Not...
Asked by
MNATV
1994
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Transmission Speed Sensor Replacement Honda
Transmission Turbine Sensor Replacement
Pilot Bearing Replacement
Online car repair manuals
