1998 Dodge Caravan Not shifting when warm?
ZAW1122
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 135,000 MILES
I need a little help before calling the repair man.
While driving the other day my van jerked a little, like it quickly down shifted. It now will not shift to higher gear after getting warm. I can start the van up and drive and the shifting is fine, until the engine temperature warms up. That is when I have to drive home again at 30 mph. My check engine light is also on. ATF level seems fine as does the color without any bad odor. I would appreciate any help, and offer any more information if it is needed.
Monday, December 8th, 2008 AT 9:18 AM
BUDDYCRAIGG
  • 2,262 POSTS
I believe your van is sensing a problem and switching into "limp home" mode.
With the check engine light coming on, the computer is storing the trouble code.
Retrieving that code may point you in the right direction.
This post should help
http://www.2carpros.com/dia/how_to_scan_trouble_codes.htm
Some auto part stores will scan your car for free in hopes of selling you a part
good luck
Monday, December 8th, 2008 AT 3:44 PM
ZAW1122
Thank you! I drove down to autozone today and got my codes. (Van drove great on the way there, but halfway back started having problems again)
my codes are
P0733 Gear 3 Incorrect ratio
P0760 Shift Solenoid C Malfunction
P1698 No Bus Message From TCM
P0700 Transmission Control System Malfunction
also: the vans instrument panel also has a mind of its own and sometimes it comes on and sometimes it doesn't.
Monday, December 8th, 2008 AT 4:48 PM
BUDDYCRAIGG
  • 2,262 POSTS
You are going to want to go to a dodge dealer to have them check it out.
The P0760 and P0700 both suggest to me a solenoid shift pack problem.
I'm sorry to say that is not going to be a cheap fix.
You might want to replace the tranny fluid in a last ditch effort. It's not difficult or expensive. And if you cant remember the last time it was changed, then you need to do it anyway.
I'm sorry I don't have better news.
Monday, December 8th, 2008 AT 5:26 PM
