My AC is not turning on; i.e., the clutch is not engaging. My mechanic has checked out everything else in the ac system. He is not getting any signal from the PCM and suspects that there is something wrong with the PCM. The PCM may also just have experienced a glitch and needs to be reset or reprogrammed. Is there a way to check if the PCM is really bad? All the other functions seems to be ok. Can the PCM be reset? or reprogrammed? without having to go to the dealer?
Oct 15, 2010 at 1:48 PM
