Engine Mechanical problem
1990 Dodge Caravan 6 cyl Front Wheel Drive Automatic
car sometimes doesn't start, just cranks & cranks. Later that day or next, will start no problem. Happens every couple weeks.
Tuesday, July 14th, 2009 AT 12:31 PM
MECHANIC
When this happens, have you checked to see if you are getting spark and fuel to the engine? One will most likely be missing. Once that is determined, then we can better diagnose the problem. Has the check engine light ever come on?
If you need instructions on how to check fuel pressure and spark, let me know.
