1990 Dodge Caravan Doesn't start
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICHAEL SHORT
What is the likely problem, it sputtered one day and the next day it started in the morning but once it was stopped for an hour it hasn't since?
Apr 14, 2008 at 3:05 PM
  • 75,988 POSTS
If its cranking the engine over and refuses to start do below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Apr 14, 2008 at 8:34 PM
