Computer problem
2007 Dodge Caliber 6 cyl Automatic 49000 miles
my 2007 caliber about 2 months ago had a new alternator, brake pads, and some kind of tire rod or something like that replaced, they said it was unusual for the alternator to have to be replaced but couldn't find any reason it went bad, nevertheless, the check engine light has come on again and i checked the gas cap as that was a problem in the past when the light came on, however the light is still on, i did the key in the ignition check to see if codes would come up, but nothing did. I have put more money into this car then I care to mention since I have purchased it, I really do not want to put any more money into this caliber. I am over due for an oil change could this be the cause of the light to come on? If the gas cap is the cause will i need to go to a shop to get the light reset or should it go off after i have checked and replaced the gas cap?
Apr 14, 2010 at 6:11 AM
