1997 Dodge Avenger cam/crank sensors
DANNNY C
1997 Dodge Avenger 6 cyl Front Wheel Drive Automatic
how do you test check cam/crank sensors in a 97 dodge avenger. should they be checked when car is having the problem, not having the problem or both. (car loses spark randomly) sorry for no donation, bad time
Aug 25, 2010 at 1:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Pin 1 is +5V, pin 2 is Ground and pin 3 is the signal. Use analog voltimeter in pin 2 and 3. Crank the engine: the pointer of the voltimeter shoud oscilate in range 0V to 5V.
Aug 25, 2010 at 1:33 PM
