dies when u let clutch out
10,000 MILES
DWIGHTGREGORY
my truck dies when you let the clutch out, unless you keep the throttle wide open. i can take off but have to keep it wide open. the motor idles low also but its always idled low. i have checked the fuel lines and cleaned them out and checked the fuel filter. i dont know what else to try to do. it ran fine before my son poured about a qt of oil in the tbi. also checked the charcoal filter.
Oct 8, 2013 at 2:22 PM
HMAC300
  • 48,601 POSTS
clean tbi with choke cleaner first, then scan for codes and check fuel pressure. auto parts can scan for codes. or cross A&B on aldl under dash lh side. look under trouble codes on site here under obd1
Oct 8, 2013 at 11:16 PM
