2002 Chevy S-10 Clutch Problems
BUTLERTTT
  • 2002 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 149,643 MILES
Iwas driving my truck and my clutch just went to the floor. I have not had any problems with this before
Friday, February 6th, 2009 AT 10:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Does clutch come back up when you let off or does it stay to the floor?
Saturday, February 7th, 2009 AT 12:01 AM
BUTLERTTT
There is no tension in it. Its just real easy to push it in just happened all at once while I was driving tonight
Saturday, February 7th, 2009 AT 12:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check the clutch fluid in the master cylinder under hood. Let me know if it is full/empty/burnt smell etc.
Thanks for using 2CarPros. Com!
Saturday, February 7th, 2009 AT 12:26 AM
BUTLERTTT
I checked one place it had a cap on it that said clutch im not sure if this is the master cylinder or not this was like a little hose it was pretty full but looked kinda coroaded
Saturday, February 7th, 2009 AT 12:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Master cylinder is kind of like the brake master cylinder and is usually located beside of the brake master cylinder. The brake master cylinder is where the brake fluid is poured at. The clutch master cylinder is for the clutch fluid. It is a small plastic-like container which holds the extra clutch fluid.
Saturday, February 7th, 2009 AT 12:43 AM
BUTLERTTT
I checked the resivor it looks like it may need fluid I use brake fluid right
Saturday, February 7th, 2009 AT 3:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, brake fluid is correct. Let me know how it feels after it is filled and bled.
Saturday, February 7th, 2009 AT 5:49 PM
