Hi there,
OK, if you have no leak in the hydraulic system, then it will be a mechanical problem, I would check out every thing very carefully, even the pedal box and linkages to the slave, some Fords here have a problem with failing welds on pedal box's causing odd clutch issues, just to be safe check this out before removing the transmission, best to be sure first, let me know how you get on.
Mark (mhpautos)
Saturday, February 27th, 2010 AT 4:54 PM
