Engine shut off while driving and now it will turn over but not start
175,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JESSCRISP614
My van was running fine then I left home and made it 6 miles away and it quit running.I assumed it was out of gas because it was very low but after adding 4-5 gallons of gas and charging the battery it still won't start.i need help, we have to get it off the side of road and I need my ride to work back. ASAP
Oct 8, 2019 at 8:34 AM
We need to find out if you have spark and fuel. The way to do this is to start with fuel because that is easier. Spray a little starter fluid in the intake to see if the engine tries to start. If not, then we move onto spark. If it starts, then we have a fuel issue. There is a chance that we have an air pocket in the fuel line that the pump cannot overcome. This is unlikely in more modern cars but it is a chance.
If it does not start then we need to move onto spark and make sure we have spark. Do this by pulling a plug and holding it against the block to see if it sparks. If not, we can go down this path.
I suspect you have a fuel issue but again, it is just a guess until we get more information.
Oct 9, 2019 at 9:50 AM
JESSCRISP614
Well, we tried everything.it is getting spark, it is getting fuel. I am at my wit's end. I don't know what to do.it will not try to start at all not st any point.it only cranks. I am just wondering if it's electrical,or something to do with the fact that the day before she broke down the steering wheel locked up and my boyfriend YouTubed how to manually release the locked steering column.he took off the cover of steering wheel and somehow unlocked it. but could that have something to do with it?
Oct 12, 2019 at 2:54 PM
Not necessarily. If it is cranking then I wouldn't think it does. However, I am wondering if we fouled the spark plugs. If it is cranking and there is fuel then we may have caused the plugs to not have sufficient spark to ignite the air/fuel mixture.
At this point, I would replace the spark plugs and then try it again.
Also, it is unlikely to have a bad crank sensor because you more than likely would not have spark but we can't rule it out yet.
Let me know what happens after you put new plugs in it and we can go from there. Thanks
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Oct 13, 2019 at 4:34 AM
