My car listed above is a custom 3100 Vin number M. My car was running rough and ticking. One day after work did a compression check which showed 150 on all cylinders except zero on number one took head. had it fixed bent a valve and dropped a seat. I put it back together, it was running rough possibly mixed up a push-rod I did not know there were different sizes. On initial start up I noticed that one rocker arm was not moving as I looked closer I noticed push-rod broken and a half hanging by a thread. I think I put a long one instead of a short one there, replaced it been China just the rocker arms ever since with no success. still shaky not running right. decided to do a compression check again no compression number four cylinder. I am stumped very close to area where I broke the rod not 100% sure.
Nov 17, 2017 at 2:00 AM
