1995 Buick Regal ENGINE MOUNTS
228,000 MILES • 6 CYL • FWD • AUTOMATIC
RAY777
How do I know which engine mount is broken? Car failed inspection.
Jul 5, 2009 at 11:36 PM
  • 110,248 POSTS
With the hood open, place the park brake on, keep your foot on the brake, place the vehicle in drive and push lightly on the gas. Do the same in reverse. THe engine will lift (more than an inch) if there is a broken mount. Also, you will be able to tell which is bad by when the engine lifts (driver or reverse). One side or the other will lift.
Let me know if this helps.
joe
Jul 15, 2009 at 4:58 AM
