1996 Buick Regal Custom engine removal
1996 BUICK REGAL
CLAUDEPIO
  • 8 POSTS
I have a 1996 Buick Regal Custom with a 3800 Series II engine.
It seems that a connecting rod bearing is busted and the engine is making a knocking sound.
Can the engine be removed from the top or do I have to drop the engine and tranny from the bottom.
Appreciate any help.
Jul 12, 2006 at 1:42 PM
XOWEY
  • 113 POSTS
oh yes, it can definitely be removed from the top! :)
when you start the process let me know and I'd be glad to talk you through it. 8)
I've been down that road many times. :wink:
Jul 13, 2006 at 3:49 PM
CLAUDEPIO
  • 8 POSTS
Xowey thank you for the info and the offer.
I will need allot of advice when I start. :)
This is a first for me.
Jul 13, 2006 at 4:17 PM
XOWEY
  • 113 POSTS
have you ever pulled an engine before?
Jul 13, 2006 at 4:20 PM
CLAUDEPIO
  • 8 POSTS
Yes, but I did that many years ago in a Blazer.
Jul 13, 2006 at 10:23 PM
XOWEY
  • 113 POSTS
this one should be easier than that one was. 8)
plus you will have a cheering section this time! 8)
Jul 14, 2006 at 1:49 PM
CLAUDEPIO
  • 8 POSTS
I am thinking of replacing the crankshaft only on this engine. What other parts do I need to replace since I will have the engine removed.
Jul 17, 2006 at 11:15 PM
XOWEY
  • 113 POSTS
[quote:775236aac1="claudepio"]I am thinking of replacing the crankshaft only on this engine. What other parts do I need to replace since I will have the engine removed.[/quote:775236aac1]you will need all the main and rod bearings, as far as the rods go, it really depends on what you find when you get in there.
if it is a rod bearing that's making noise you should be able to determine which one it is before you get into it. with it running you can unplug one injector at a time and listen for the change in sound..........the one that causes the most drastic change in the knocking noise is usually the failed bearing :wink:
Jul 18, 2006 at 3:05 AM
CLAUDEPIO
  • 8 POSTS
I have managed to take the engine out and I am dismanteling it.
I got the pushrods mixed up and a couple of them fell on the floor while I was removing the heads.
Is it ok to reuse these or should I replace them.
Jul 23, 2006 at 2:08 AM
XOWEY
  • 113 POSTS
sorry it took me so long to reply, I was out of town for a couple of days. :wink:
the push rods are all the same length on this engine. as long as they aren't bent you should be ok. :)
Jul 31, 2006 at 1:34 AM
CLAUDEPIO
  • 8 POSTS
Thanks for your reply Xowey.
BTW the engine is rebuilt and back in the car. It is working fine. I am pleased so far. The 500 KM oil change just came up, so I will have a look at the oil coming out of the engine.
I have a question though. The temperature guage stabilizes at the second mark when the car is moving however as soon as I stop the temperature rises to the third mark and then falls back when I start moving again. The guage has 4 marks before it gets into the red. I changed the thermostat and the fans seem to be working fine, the coolant level is fine also. I was wondering if this is normal.
Any ideas.
Aug 13, 2006 at 12:51 PM
XOWEY
  • 113 POSTS
oh yea, that's normal with the a/c off, the fans only run above a certain engine temperature (about 225 f) :wink:
with the a/c on they come on with a/c pressure activation
is it more stabalized with the a/c on?
Aug 21, 2006 at 8:59 AM
CLAUDEPIO
  • 8 POSTS
Thanks alot, I was getting worried. I have not tried the A/C since engine rebuild.
Aug 21, 2006 at 10:51 AM
XOWEY
  • 113 POSTS
[quote:9d9345725d="claudepio"]Thanks alot, I was getting worried. I have not tried the A/C since engine rebuild.[/quote:9d9345725d]sounds like you'll be alright, is everything good now?
Aug 27, 2006 at 4:26 AM
CLAUDEPIO
  • 8 POSTS
Everything is fine...
Thanks....
Aug 27, 2006 at 1:01 PM
XOWEY
  • 113 POSTS
:D
any time!
Aug 29, 2006 at 10:56 AM
